Microwave help please
M-J
Cambridgeshire, UK
Rapido 986F
Getting there!
Does anyone have this Sanyo microwave in their MH, it was fitted to loads from about 2008 - 2013 I think. Definitely swift and bessacarr etc.
I need a photo of the interior glass plate so I can find the correct replacement. Both myself and the wife can’t remember what it looks like and it’s now in hundreds of pieces following a slight mishap!
Any help appreciated thank you
You could probably google the model number and find a replacement. Good luck (y)
Tried that after eventually finding the model number but it brings up different looking plates and microwaves!
What kind of drive does it have? does it have a 3 wheeled trivet?
I think any plate of the right diameter should fit. If you can find one that has a 'clear' line the same diameter as the wheels, so much the better. What model is it?
Had to find one on google and it said sanyo em-s1298v
Can’t look on mine without fully removing it.
A quick look shows plates with a 'drive' in the centre but yours didn't have one ad you have a closed trivet.
You need something like this
Amazon product ASIN B016C5UYXOIt is just a flat plate you just need to measure what size you need.
Edit:
If you have an ad blocker on you will need to pause it to see the link.
A second look at your trivet suggests it may not be a flat plate after all. it may have 3 drive teeth in the middle to fit in the holes in the trivet.
Can you remember if it was flat?
If unable to locate the part for your old microwave having tried earlier posts, be mindful that a new microwave with front fixing kit are offered online for very little money.
We have a 2011 Bessacarr and the microwave looks familiar, can't check it at the moment but will have a look
tomorrow and get back to you.
Reactions: M-J
@M-J
The microwave is Sanyo EM-S1298V. The glass plate is 24.5cm diameter with a slightly higher outer edge.
Underneath there is a raised circle and the three rollers are inside that circle.
The picture is from e-bay (if I managed to upload it correctly) but when we broke one on a previous 'van
we just bought a clear plate from a charity shop for a few pence.
I did take photos but have been unable to post these. I'll have to have another look at the instructions.
Dave & Jane
Reactions: M-J
I think that I managed it this time but my camera skills are on a par with my computer skills -
next to useless.
Anyway, I hope all this helps.
Reactions: M-J
Thank you @dwite
Based on your photos I have purchased the one from eBay
Fingers crossed.
Thank you @dwite
Fingers crossed.
Did the flat plate fit and work in your microwave.? I now have the same problem with same microwave.
Note to myself photograph my Micky plate and any changeable parts in the van. That’s today taken care of😀😀
