Mercedes Seat
BuilderBob
nn297tl
E745 Bessacar
12yrs
I have swapped the double seat for a single in the front of my Mercedes Sprinter conversion, this has raised a 'seat restraint fault' light on the dashboard, any ideas how I solve it?
Stephen
I can't help but hopefully someone who can will be along soon (y)
You could remove the seat occupants sensor from the original and insert into the new seat. Or, as outlined above with a 2.2ohm resistor but you will need to check the pins to which the resistor needs to bridge. You can find this out by looking at the two parts of the detached plug to determine which pins were in contact with each other. Of course there may be 3 pins and you will need a multimeter and soldering iron. HtH
