busbuddy
Driving to work this morning and all the electrics died, it cut the engine and all dashboard.......even hazards wouldn't work
Couldn't find anything obvious, battery had good power so removed it to check all major fuses/bars on the positive terminal.
All were good (tested with multi meter) so put it all back together and van started. Went under bonnet and yanked all the wires to check for loose or nibbled, nothing.
Drove it 200 yards.....cut out again, same as previous so stripped out battery again and traced all the wires, couldn't find a thing
Put it back together and it started and so I drove slowly the 2 miles back home.
Will have a look again tonight but can anyone think of anything that would cut all the power, it was as if someone disconnected the battery only thing I can think of is maybe one of the fuses/bars on the positive terminal is breaking down?? but not permanent yet
I could understand if engine died but dash still live and vice versa but to loose everything in one go is odd
2003 2.8 fiat and it's nothing to do with alarm
