Mains unit getting hot (5 Viewers)
cbrown1360
99
29
Lymington
Since 2014
The mains unit located under one of the bench seats on my Elddis Accordo 105 is getting hot and giving off one of those "electrical" smells. I am on EHU with only the fridge drawing power. I believe the mains unit has a cooling fan but this hasn't tripped in yet either because it doesn't work or because the mains unit is not hot enough to trip it. I've had the van from new for over 2 years and have only noticed this in the last couple of weeks. Is this normal or anything to worry about?
May 8, 2011
3,867
48,556
God's county. Helmsley, North Yorkshire.
IH Tio 630 RL
Since April 1846 but have always camped.
Not sure if this is relevant or not but my master unit was doing the same and it turned out to be a knackered battery and the master unit was overheating trying to charge it.
Techno
Jul 28, 2010
15,475
20,756
Leeds the one up North
Rapido 7090F 3 litre 160
May 2010
My thoughts exactly and if CBE equipment is fitted it will be a 516 charger (grey box with a red illuminated on/off button)
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
Was a newbie, now a Middie.
The transformer in our boat mains unit charger did the same, then started smoking. Keep your eye on it, sounds terminal.........:(
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Picture of unit attached.
Techno
Jul 28, 2010
15,475
20,756
May 2010
I really don't recognise that unit but I doubt it has a fan. I can see clearly that the left hand breaker feeds the fridge & the charger but where is the charger?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Personally I would check the tightness of all connections but in your position I would put the fridge on gas and turn off the charger/fridge switch and see if the smell goes within the hour. Also note the battery voltage with the charger off
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Another picture from above.
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
As suggested, I've put the fridge on gas and turned off the fridge / charger breaker. The battery is showing a charge of approx. 12.3V. I'll report back later on whether it's still hot or smelling. Thanks for your help.
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Don't know if it's relevant but if I turn the fridge / charger breaker back on there is something in the mains unit that sounds like a fan that starts running but it stops after about 20 seconds.
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Nothing turned on - from memory the battery charge has never been more than 12.5V.
Tootles
Sep 14, 2013
9,511
34,800
Lancaster
That could very well be the transformer plates vibrating, as ours were. As Brian says, don't leave it switched on when your not around. If it stinks, it's bu**ered.
Techno
Jul 28, 2010
15,475
20,756
May 2010
That can only be the charger. carry on for now and as Brian said feel the battery sides for heat . Keep an eye on the battery voltage
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Just to be clear battery charge is 12.3V with charger isolated and 13.1V with charger on.
Techno
Jul 28, 2010
15,475
20,756
May 2010
The battery at 12.3 is at about 65% and in such a condition the charger should be giving far more than 13.1
19,369
30,344
But if the battery is 12.3 after being on charge it is knackered anyway, if it reads 13.1 with the charger on the battery should have something in it, if the battery was getting hot I would say that the terminal voltage was low as it was all going into heat.
Techno
Jul 28, 2010
15,475
20,756
May 2010
12.3 is the residual reading having just turned the charger off. If it is knakered it won't be too long before it drops sub 12 volts
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Am I right in thinking that when mobile i.e. engine running, the leisure battery will be charged from the alternator?
Techno
Jul 28, 2010
15,475
20,756
May 2010
Yes unless a fuse has blown on the split charge.
If it is charging with the engine running you would see over 14 volts on the battery
cbrown1360
cbrown1360
99
29
Lymington
Since 2014
Interestingly when I start the engine the voltmeter shows 0V
