I’ve turned the gas supply off on the LPG tank on my Auto sleeper kingham 2017. But gas still seems to be coming through. Its an under slung LPG tank and ive crawled underneath and removed the cover and turned the tap to the closed position. Could it just be residual gas in the pipe?
Have you just filled the tank?. If the shut off valve didn't operate correctly or you tried topping up after the first shut off you could have some liquid gas past the tap. Light a ring on the cooker as suggested it should burn off
