Podimore at A37/A303 roundabout or Lydford on FosseI’m driving from Frome to Portscatho in Cornwall next week. Anyone know where I can get some lpg on route. My local place in Frome has had their pump out of order every time I’ve looked in there recently.
Do you live in frome? We doI’m driving from Frome to Portscatho in Cornwall next week. Anyone know where I can get some lpg on route. My local place in Frome has had their pump out of order every time I’ve looked in there recently.
I am in martock off the A303Do you live in frome? We do
The UK male spigot seems to be missing from your set up, to couple to pump nozzle. Best place to purchase adaptor spigot?
Are your taps all turned on? Yes
Where did you isolate it? Just at red taps , already reversed although did forget to open when hooked up and put Truma on to heat water but I think the 240 would override. Should still have gas to cooker though
Revrese your procedure and listen for gas at the hob??
Thanks for the tips. Where would I find solenoid valve? Do I require a competent gas engineer to correct it and get my supply back online?Your 4th picture is showing the appliance isolation valves in the on position.
You should never touch those valves they are purely for servicing or isolation of a faulty appliance, just isolate gas at supply , do in your case the solenoid valve.
You will require this Bayonet fitting for filling :
Autogas LPG Flush filler to UK Bayonet
This adapter will simply screw into the “Flush” or “flat” type filler sometimes found on LPG vehicles and on Motorhomes that have a fixed bulk domestic tank with an auxiliary filling point for use with the Bayonet type filler gun.autogasshop.co.uk
Solenoid should click when you operate the switch on your gauge if you have one ,Thanks for the tips. Where would I find solenoid valve? Do I require a competent gas engineer to correct it and get my supply back online?
Okehampton services on th A 30I’m driving from Frome to Portscatho in Cornwall next week. Anyone know where I can get some lpg on route. My local place in Frome has had their pump out of order every time I’ve looked in there recently.
Trago Mills just off the Exeter to Plymouth Road at Drumbridges roundabout. Bit of a pain having to queue as it’s the cheapest fuel station for miles.I’m driving from Frome to Portscatho in Cornwall next week. Anyone know where I can get some lpg on route. My local place in Frome has had their pump out of order every time I’ve looked in there recently.
Exeter, marquise.I’m driving from Frome to Portscatho in Cornwall next week. Anyone know where I can get some lpg on route. My local place in Frome has had their pump out of order every time I’ve looked in there recently.
