Paul J
- Feb 27, 2018
- 220
- 40
Hi guys, I've probably posted about this previously. Having had a motorhome around 20 years ago, of similar size to my current one, and using exactly the same (6k Propane ?) bottles, I'm surprised at how much gas I'm getting through, even in summer. I'll be honest, we're often not on a site, and when we are, we don't use the electric, we also cook in the van, and heat the water on gas. We are however, super economical, we put reasonable thought into when we should use the heating, it's turned off when we leave the van, and we don't leave the water heater on, or the fridge on full cold. We're lucky to get much more than two short weekend breaks in the middle of summer out of one bottle. Maybe I'm just plain unrealistic ?
so..... my gas supplier doesn't keep larger bottles in propane, and is Butane a different screw-on fitment *** ? pressure ? or, there was a reason why I'd never managed to use larger bottles in this or the last motorhome ?
to LPG : I've seen the 'Gas-It' kit and would fit one of their larger plastic type bottles, think it was £150ish ? and would quite likely pay for itself in convenience and cost of the fuel, the other bottle would just be kept as spare.
however, when I've looked online, whilst I can find some LPG filling stations, they seem a bit thin on the ground, is LPG dying out, or will it die out ? is it going to be worth an LPG kit ?
many thanks for reading, any comments much appreciated
Paul
*** I never used Butane previously because I believe it's not as good at cold temperatures ? however, if more readily available in the larger (11kgish ?) size, then I could keep one for summer use ? (unless the LPG kit works out)
Paul
