Squeak
- Dec 8, 2019
- 85
- 109
- A Class
- Newbie
No reply from the OP , perhaps they've managed to get refilled
Never replied to the last thread they started either.No reply from the OP , perhaps they've managed to get refilled
I am guessing you have a fixed bayonet ?If it’s a refillable system you don’t need an adapter, only when filling abroad.
Give em a chance lads and lasses..Never replied to the last thread they started either.
Last seen 3 minutes after posting this thread
That's not the way to get help
Do on mine.If it’s a refillable system you don’t need an adapter, only when filling abroad.
I appreciate you have a duff signal, but is there any chance of posting a pictureSorry for not answering back we have very little to no signal, not being rude by not answering. We have an under slung tank but cant connect a hose line to it from the pump. Thank you for all ure reply's & thank you to Ingwe, we will try ure suggestion tomorrow.
Many thanks
Coral
i think you need one of these to screw into the gas inletSorry for not answering back we have very little to no signal, not being rude by not answering. We have an under slung tank but cant connect a hose line to it from the pump. Thank you for all ure reply's & thank you to Ingwe, we will try ure suggestion tomorrow.
Many thanks
Coral
That only works if the vehicle was built for the UK. Mine uses an adaptor but the thread is only 10mm metric for screwing in.i think you need one of these to screw into the gas inletView attachment 354152
Why?Do on mine.
No way of connecting a filling hose without as the inlet is just the standard threaded connector.Why?
And the same with mine. I carry 4 adapters because I need one for the UK bayonet fitting hoseNo way of connecting a filling hose without as the inlet is just the standard threaded connector.
Can I ask what type of systems you have fitted?And the same with mine. I carry 4 adapters because I need one for the UK bayonet fitting hose
Yes I had to buy 10mm to bayonet & 10mm to spanish to screw in to my existing which is an Italian/French internal cup with German acme thread on the outside , which is the original.Our Citreon Xantia was like that, while in France someone sent us a set out, but they was the big ones, so we got a Frenchman to put thread in the UK one we had so the others screwed into it. ?
But looking at this set the UK bayonets got a thread in it. ? Bob.
Dish (M10) to All Europe Adapters SET
Set of 3 adaptors converting UK Bayonet LPG Filling Point to filling nozzles in for ie. Holland, Germany, Belgium, Ireland, USA, Spain, Portugal, United Kingdom, Norwaywww.lpgshop.co.uk
