- Sep 25, 2023
- 683
- 846
- Swift Sundance 590RS
Was away over the weekend in our 52 plate swift and lost the drive belt on the journey home. Managed to limp home with no battery charging or power steering (Leisure battery was charging through the split relay from the engine battery even though the engine battery was not charging). Its a Fiat Ducato November 52 (X244 I think is the model) 1.9 diesel. I hope its just the drive belt to replace, hydrualic pump for the power steering looked OK as its on the top of the engine, but it was too wet to look at the alternator. Worse case it could be we lost the alternator pulley bearing and it will need replacing. Question is if I do need a new alternator, what size is it?
I think the standard is 55AMP or possibly 90AMP, could it be a 90AMP or bigger as it is charging the engine and leisure batteries through the split charge relay. Is there any way to tell the size of the alternator.
