Looking for a replacement 90 degree pipe for my Rapido motorhome
zac
Basingstoke
Rapido A CLass 10000
since 2013
My Rapido has had a very small water leak in the back garage which up until now has eluded me, this morning i took another look and found where it is leaking. It's this 90 degree pipe on the right that is leaking from the join. What are these called and anybody know where i can order one from? This is basically the freshwater drain but water sits in this all the time up to the tap which then blocks it off until needed to drain. The replacement option is just in case the repair does not work with pipe sealant.
Motorhome is a Rapido 10000DFH
Thanks in advance
It looks like 40mm European size pipe. Can be found at aquarium/pond suppliers. Link below to a 90 degree solvent weld fitting.
Could you use some pipe weld glue, or whatever it's called to stick it rather than replace?
Yes, that's what I intend to do but the replacement is a last resort just in case. I should have added that to the original thread sorry.
As a cheap temporary fix (the sort that usually end up left permanently) good old gaffer tape! 😄
  • Informative
Reactions: zac
On second thoughts, if it's freshwater drain it will be a smaller European metric pipe size. Link below to supplier for various pipe and fittings sizes.
  • Informative
Reactions: zac
thanks, yes it is smaller for sure probably around 30mm without measuring which i will do shortly just to be sure. Thanks for the links, i am assuming it does not matter where the pipe comes from as long as it fits?
its only as a last resort really just in case the fix does not work.
As long as it's European/aquatic size then the supplier doesn't matter. Be mindful that 'normal' UK solvent weld pipe and fittings from builders merchants is a totally different size.
  • Informative
Reactions: zac
great very useful thanks for replying.
Think it's all been said above.
Imho It is a 90° solvent weld elbow that you may be able to fix with a liberal dose of solvent weld adhesive. But it won't work if there is moisture present.
Measure pipe diameter carefully - maybe Toolstation have the correct size. If it's small maybe overflow or conduit elbows will fit.
  • Informative
Reactions: zac
On my rapido tank I had to get a sleeve printed to make 40mm pipe fit. If it were me I would try plumbers solvent adhesive first. After draining the water and drying. Otherwise you will have a problem making up the pipe you cut off. Or even 2 part epoxy putty would do if not. It's not under pressure
  • Informative
Reactions: zac
its not a 40mm pipe its smaller than this, i will be trying the plumbers adhesive first though for sure, the replacement pipe is a last resort and i will then keep them as spares.
thanks for the assistance.
Might be a bit more to do if the original is solvent welded
  • Informative
Reactions: zac
You can often unstick badly fitted solvent weld joints with a PHG but go slowly and carefully. Replacing that elbow really means re-plumbing most of that area, OK if you’re confident with that. It doesn’t look like classic PVC or even UPVC piping and joints but more like HDPE which shouldn’t be solvent welded as it’s usually designed for push fit or heat fit, sometimes people do silicone it though… (it does sort of work).
It you want a first class bodge solution i can highly recommend Gold Label underwater sealant as this stuff will cure on wet surfaces, they used to sell a small tube for about £15 that works well on these small annoying jobs (used it several times).
will take a look at that as don't want to replace the whole lot if I can help it.
So quick update, amazingly all i did was push it and it moved about 3mm and now doesnt leak, no idea how it came loose to start with it but will monitor it to see how it goes but its not leaking at the moment. Will print a small box and put a piece of sponge in it to see if it leaks moving forward as at least that way it wont go into the garage and I should be able to see the sponge get wet if it does. Going to get some plumbers weld as well just in case, thanks for all the replies.
As it isn’t under pressure this would fix it.
  • Informative
Reactions: zac
Any self amalgamating tape would be ok for that application.
Glad it’s sorted ?
  • Informative
Reactions: zac
Glad it’s sorted ?
I hope it's sorted, i did order some of that Gold label just in case and will keep that in the Motorhome as when away if it does happen i will have something to sort it quickly. I am assuming vibration has caused it to move over the last 6.5 years as cannot see any other reason for it to come loose.
And you found another use for your 3D printer, i reckon you pulled the pipe out yourself 😂
Motorhomes always gives me nightmares as there is always something that needs fixing, i sometimes wonder why i put myself through the pain :) luckily a tiny box will be simple to make and may save me a lot more work unloading the blinking garage every time i see a little bit of water. :( pretty sure the motorhome has given me OCD lol
