Rockpool
Question that probably been asked a million times but Looking for your thoughts. I have a pair of 110ah lead acid batteries and one of them is not holding charge. So have been debating with myself
for a few months on going down the lithium route. So not wanting to open a can of worms
I’ve been looking at a set up that we think suits our needs which I've attached below.
As we mainly wild camp all year round, have found that our 285W of solar is not enough to keep the batteries charged up in the winter so thinking B2B is the way forward. The inverter, thinking as it also includes an ac-dc battery charger (need a new battery charger anyway as the EC 500 Sargent panel on board won't cope with lithium) might be a good idea? Save space and cabling.
Equipment:
Thinking of making and installing a bus bar to make the connections easier and neater I hope
along with using Mega Fuses at the bus bar connection.
Cable sizes noted as recommended by Renogy.
So any thoughts on the layout would be appreciated as iam no expert by any means but enjoy the challenge
Equipment:
- Pair of 100Amp Renogy Lithium Batteries.
- 2000W 12v pure sine Renogy inverter/battery charger.
- 12V 60Amp B2B Renogy Charger. (not sure if we should go for a 40amp instead as not 100% sure of the alternator size as cant find the label on it and its tucked away under plastic shrouding our van is a Fiat Ducato 2.3 maxi 2017)
- Duoracer 30amp solar MPPT (existing)
- Planning to use the Renogy BT-2 along with the communication hub to hopefully allow everything to be monitored.
