No, as neither are driven axles, hence the term tandem.If levelling the rear does it matter which axle you raise. Is it best to reverse on or place in front of the first axle and
drive on forward.
Were they the taller Millenco ramps Simon? Mine (in the photo above), have never got jammed. A quick shimmy right or left of the steering, sees them left behind for retrieval a few minutes later.I drove off the front of mine recently spinning on wet grass. The ramp got jammed under the wheel and the chassis. Had to jack up the van to remove it.
