agentdagnamit
- Jul 22, 2022
- 4
- 2
- Mazda Bongo
Hi everyone, this is my first post.
I’m trying to understand (in a simple way) how my starter and leisure batteries work together in my Mazda Bongo. The van also has a Zig unit. The main appliances running off DC (when not hooked up) are a 12v/240v fridge, led lights and the radio.
I’ve had the van for about 7 years, mostly things are fine, but occasionally I seem to manage to drain the starter. I also suspect the leisure battery could do with replacing as it is over 4 years old and gets several months of use each year.
I definitely have some sort of split charger, and the Zig unit is capable of recharging the batteries when hooked up. It can also provide AC power to the fridge.
A couple of things are confusing me:
A few days ago (in 30+ degree heat) the fridge shut down after less than 10 hours (on 12v). But as I write this, it has been running for 14 hours and still going strong. The leisure battery reads about 11.8v
But, the starter battery also reads about the same. It seems like both batteries drain and recharge together, even whilst the van is parked up and not on EHU. Shouldnt the starter battery sit at around 12.4v or more (ie ready to start the van, and then recharges via the alternator). I thought the split charger relay would isolate the leisure battery when the engine is off.
I just disconnected the leisure battery, and the fridge continued to run. This was surprising! Should I be worried? The fridge probably has a voltage based auto cut-off, but isnt that designed to protect a slow discharge leisure battery, not a starter type battery?
The Zig unit has a “Car or Caravan” battery select switch. I’ve taped this down so it always selects the leisure battery. Why would I want to draw power from the starter? It also has a battery indicator (red or green light) – but it only ever shows green (for good).
Sorry, a long message. Maybe this comes down to me trying to understand why the relay isnt blocking off the starter battery when the engine isnt running (so all appliance can ONLY run off the leisure). Or have I misunderstood what the relay is supposed to do. Someone suggested that I check it isnt stuck, but I wouldnt know how to identify it (I cant seem anything other than fuses wired in line with the battery leads).
