On the newer (say 2011) B class Hymers if I was to buy a left hand drive, what can be done with the lights when driving in this country ? do I have to buy new lights ?
No, you can adjust them by a lever on the back of the light. Post again when you have the van and I can tell you how to do it.
Hi Busybuilder,Hi Xabia, is that a B544 you have ? that's the van we're after, only seen one so far a pretty poor example in Livingstone. When we get sorted with our current van we'll be off to see one at Bundesvan. Is there anything particular that we need to check on them ?
Not true they kick up to the right you adjust a leaver on the back of the dim unit for flat dipping.We have a 2008 Hymer our garage told us the lights are flat so don't need adjusting.
A 2011 van will probably have them as standard well not quite they come in the Komfortpack which includes a drivers door, air con, electric mirrors, cruise control etc. Don't think they will sell you a van without the Komfort pack.That explains the 544 at Bundesvan having Goldschmidt suspension.
Not quite true, if they are LHD they are adjustable between LHD & flat dipping or if they are RHD they are adjustable between RHD & flat dipping.Hymer headlamps are adjustable for RH or LH, no need for new lights. We change ours over every time & it's works fine.
