LEDCOM DRL and replacement LED DRL Black headlamps
Euro330
Banned
Carnoustie
Bailey Advance 640
About 5years
Anyone dabbled with above.
Looking at fitting Ledcom DRL lower lamps to Bailey Approach Advance 640 2016. Made specifically for the lower grill round or oblong cavity for the van. Watched the youtube vids look easy enough.
Also replacement Black LED DRL headlamps from some of the many online suppliers.
As much as I am a Bailey enthusiast for build quality (compared to some) and habitation ALU-TEC wall construction I think they look a bit bland. I have placed Bailey decals from other models to front and side, bonnett protector and alloys next.
Any hints tips for above would be gratefully taken on board.
Im not bad with my hands, did full loft conversion and conservatory on house, but i dont like electrics.
I fitted these to our Approach 620SE and it's all quite straightforward. The only tricky bit is tapping into the dipped beam feed which is behind the nearside headlight assembly, so this has to come out for access. If you can mount the relay in the engine compartment close to the main fuse box, that's a help. The Ledcom instructions are very clear and shouldn't present any problems
Cheers. No probs once fitted Diggly?
None at all, they work very well, but basically it's fit and forget. A nice touch is that they stay on for a few seconds when you switch the engine off, so you have some light to find the front door key hole.....
Great stuff. Yeah they sound like the next job, look quite smart aswell.
