Led.com DRL's to A class
Great Totham
PVC
Since 2015
I have bought some LED.COM DRL's to fit to my Globetrotter in place of the blanked off bits that would look better with lights in.
I've read a few thread on these on here of how simple they are to fit and not so for me.
The section where you connect the "white or yellow" wires to the loom behind the passenger headlamp I don't get. I'm guessing because mine is an A class and the lights are not std Fiat Ducato lights. So what do I do.
I even gave up and thought I'd contact an auto electrician but that not as easy as it sounds so I'm back on the DIY case again.
Any help I would appreciate.
Cherers
So what wires do you have behind your headlight or side lights? Do you have other running lights you can tap in to? Pictures?
I fitted a set to a standard Ducato front end years ago. You need to connect to the sidelight live so that is turns off the DLR's when you turn the lights on.
If in doubt give the guy art LED.com a ring he is very helful.
Its just a case of connecting to the wiring behind the light that feeds the sidelight circuit and on most a wire to an ignition switched live
OK guys cheers. You given me confidence to get back in there tomorrow.
(y)
pictures ... the lead you can see is the one that goes to the running lights in the headlamp. I guess I need to open it up and tap into one.
