If you spend a lot of time in hard water areas you will encourage scale build up as Lenny pointed outYou will probably need to descale it more often.
Now that another q haYou will probably need to descale it more often.
I use white wine vinegar (stock up in France at 30p Lt) about 3 Lt to 10 Lt water draw it thriugh the system until all pipes an boiler are full. Run boiler on hot for a couple of hours then flush well.Now that another q ha
How you do that
The electric elements are prone to failing and a pig to replace. Best to use as little as possible.On electric I'd never even considered turning it off unless I wanted the amps for something else. On gas, I turn off at night just to reduce gas consumption and noise, but would leave on in ultra cold weather.
No it's wasteful of energy. Why would you it heats up quickly when you do need it.
I don't think this is correct because the heating can run without water in the system and I'm sure that when there is water in the system it doesn't get hot, barely takes the coldness off of it.If you leave your heating on.. your water is hot by default on the Combi 6e
Are you sure of that ?If you leave your heating on.. your water is hot by default on the Combi 6e
Yes it can... But if there is water in there .... It gets hotI don't think this is correct because the heating can run without water in the system and I'm sure that when there is water in the system it doesn't get hot, barely takes the coldness off of it.
Descale using citric acid(Amazon supplies it) mix with one tablespoon per litre in a watering can and fill your freshwater tank. Run through the hot water and heat it to high temp, pull some through the taps to go into your waste tank, hot and cold, approximately half the tank. Turn off the water heater. Go for a run around the block to swish it around. Pull through the water until almost empty. Drain waste and fresh tanks, refill fresh water and pull through, heat water, pull through, drain etc.
I flush twice after the citric solution and the water draining through the waste tank outlet is clear. Good to go. As a tester, if you have a scaled up kettle, try it out, you will be pleasantly surprised.
