Leaking shower mixer tap
Steve Simmo
Globecar Globescout
HI there
we have a leak coming from under the mixer tap in bathroom of Globecar Globescout. Been told the whole tap needs replacing . Anyone know the make and whether other models can be fitted. ? Thanks
Looks like this
Yeah that is the same - you can swap the shower head with the switch over 👍
the red, blue and shower head hoses have plastic fittings with o-rings that plug into a triple socket `9hot and cold inlet / hose outlet) in the bottom nylon moulding of the tap and are held in place with a steel pin is pushed in and runs across the moulding that locks the three hoses in place - it is possible that one of the fittings has popped out of the Steel retaining pin and has become free - if that is the case - it is possible to remove the tap by loosening the retaining brass washer that holds the tap to the underside of the worktop, pushing the steel pin out, relocating the hoses, then reinserting hte locking steel pin.
otherwise it is a remove the tap, disconnect the inlet red and blue hoses and replace whole tap
Reactions: f6c
Thanks gerry . Will have a look in the light. Much appreciated.
See here for photos
