Blue Knight
G'Day All,
I'm seeking some Funster wisdom on my potential battery set-ups for our boat. I won't post this on the boat forum as they are a fairly unforgiving lot to newbies and expect everyone to have a degree in electrical stuff - I don't so here goes:
Specifically to my charging set-up I have an onboard Mastervolt 80A EHU/Shoreline charger and a secondary 110A alternator for the 4 x 110Ah wet Leisure batteries. (The batteries may need replacing though).
My intention is to add a Victron Smart 100/50 MPPT Reg and c.700W of split panel mono solar to the top deck. The panels will be mounted on angled platforms to help maximise the solar efficiency (by 30% over flat panels).
My question relates to the following diagrams in terms of me achieving the best charging/equalization for the batteries etc (I'll be using 12v batteries for now although I may consider the use of 6v Trojans and linking them accordingly).
..........so chaps, which would you consider to be the best industry standard wiring application for the following 4 or 5 battery-sized banks please.
I'm also wondering if you could swap the load wires around a bit so that the two load wires were derived from the two outermost batteries in each of the diagrams below.
Any help/input would be much appreciated.
All the best,
Andrew
1. 5 x 12v battery bank (replace the starter battery with a 5th leisure batt).
2. 4 x 12v battery bank albeit the inverter and solar symbols are missing from this diagram:
All the best,
Andrew
