Lagun Table Leg
Bristol
Pilote G740
Since 2019
Hi we have just collected new to us Pilote G740 C but the table is huge and not very adjustable.
We are going to replace with a Lagun leg and table top.
We are thinking 65cm X 60cm for the table top I think this should just about be enough for four people (most of the time just two of us).
Does anybody have any recommendations for suppliers of the table tops also what material?
Thanks in advance.
Hi.When I replaced my table for a Lagun make I bought the leg and table top from a company named Marine teak based in Lowestoft. The table top is made from teak and of very good quality. You will find their website on Google.
Thanks but I think they might have closed down🤔.
Have you been happy with the Lagun set up?
I am well pleased with the Lagun table set up. You can position the top in any position to suit your needs. I transferred it from my previous MH into the present one as it is much more versatile than the one fitted by swift. I didn't know they were now closed. A shame as they were a good company to deal with.
This was the cheapest Lagun leg which was in stock I could find;
Thanks that’s the best price I’ve seen so far.👍
I want to try and source a table top and then I’ll order the Lagun leg.
Appreciate your help.
Actually I’ve just ordered it.
I thought it might be best to get the leg and then I can play about with it and make a final decision on the size of the top.
Thanks for the link👍
I second this. The Lagun table is one of the best things I have ever bought for my Van. Brilliant.
Gromett do you know roughly what size table top you have and how many people you think could sit around it to eat?
Mostly there is just the two of us but occasionally 3. We reckoned on 65 X 60 cm?
If only they made a floor mounted one
I have seen a video where a chap modified the leg to fit the existing floor holes in his van. I will go and look for it but it was part of a longer video and not detailed but worth a look to see if it gives you an idea.
Here, from 7 mins in
Any van convertor will have spare panel board to make a table top and they should be able to edge it. I had my convertor make 2 table tops in the same worktop as the kitchen units looks smart and neat.
Thanks for all the info guys I’ve now ordered the Lagun leg and table top made to measure out of corian from a kitchen worktop company in Somerset. Hopefully it will all work out I’ll post some pictures when completed.
Thanks again👍
Hi All
We had the Lagun table leg and top fitted today. Had to put a block on that holds the bracket so that it clears the cushion but also adds some strength but pretty happy with the result it’s freed up a lot of space. Pictures attached.👍
