Wraithwrider
- Jun 4, 2022
- 5
- 8
- Mk6 Transit
Hello all
I've just put a post in the 'introduce yourself' section.
Our van is a Mk 6 Transit that's had a high quality conversion done by persons unknown. I have no wiring diagram.
We've owned it for 4 1/2 years and 10,000 miles.
3 fuses in the fuse box have been failing and this area of the box has been suffering a lot of heat damage. The centre fuse of the 3 is I have discovered the fuse for the fridge from the front 'CAR' battery. I've sort of worked out that this 10 amp fuse wasn't blowing straight away but it was running hot and damaging the 10 amp fuse to it's left and the 30 amp fuse to it's right.
The fridge is a Dometic 3 way unit rated at 120W. Simple maths tells me that the fuse should have been a 15 amp one (my local van electrical expert confirmed this) and I replaced it this last short trip to Kielder (we got back today) with a 15 amp fuse hoping that all would be well.
Previously, when this 10 amp fridge fuse blows I lose voltage indication when the switch on the panel is selected to 'CAR". Oddly however the fridge still works on 12V and the Leisure battery drains. I have been told that the fridge isn't supposed to operate from the leisure battery so this seems odd.
When I fitted the 15 amp fuse I ran the engine and switched on the fridge with the voltage meter selected to first the CAR battery and then the VAN one. Both voltage levels dropped a fair bit (surprisingly so) when the fridge was switched on and the engine note changed too.
Yesterday when we stopped the 15 amp fuse had blown itself apart! The adjacent fuses are fine. The fridge wasn't working on DC from any source now. When hooked up the fridge worked fine on 230v.
This morning I put a 10 amp fuse back in the fridge socked and didn't turn the fridge on, to check out a possible earth short. The fuse is good and for a change the leisure battery kept it's charge.
So there seems there was a connection between the fridge and the leisure battery.
I'm wondering if the fuse blew because the low charge leisure battery was taking current from the CAR battery as well as the fridge current?
An option is to try replacing both relays I guess, if they could cause an odd fault like this.
Any ideas?
Peter
Any ideas?
Peter
