Isolator switch under drivers seat of 2010 ci carioca 656
Pmcm
2010 ci carioca 656
The isolator switch has the usual on/off the thers a thunderbolt icon ?
Im just wondering is this the charge symbol should i have it in this postion when connected to 240 hook up ?
Apologies if this has been coverd a thousand times i cant seem to find anything on the net or in hand books to confirm this 3rd position?
Thanks in advance
We used to fit those switches to isolate starter battery. Does the vehicle start when that's switched off.
hi joka yes it starts no matter what the position if i turn it off none of the 12v stuff work in the back but they will work on both the on and thunderbolt setting
I think your motorhome has, or had, an inverter, to change 12v DC to 230V AC. It looks like that is an isolator which switches (or switched) the 12V on to the inverter
That is what it is for then.Turning off the habitation 12v systems.
Yes turning it off/on is 2 settings just wasnt sure what the 3rd setting is for then👍
Looks like you can see the back of the switch. How many terminals are on the back of the switch?
