MisterB
- Feb 25, 2018
- 7,101
- 16,717
- Adria 670 SLT
- enough to know i shouldnt touch things i know nothing about ....
?☠Yes it could be done
Be great for Glastonbury???☠
There are alternatives, many sites and Farmers fields have Pylons
Street lights? Telephone boxes if there are any left.?☠
? you have sussed it, me thinks phone boxes might be the answer ther'e already low voltageStreet lights? Telephone boxes if there are any left.
Used to have a tenant in my house, we had a phone box outside the gate, he had both the phone and electric wired up to the house.? you have sussed it, me thinks phone boxes might be the answer ther'e already low voltage
I think THE CURE would be better!!??Be great for Glastonbury??☹
How? The charger communicates with the car in order to determine maximum power transfer and voltage. The feed is then adjusted to match the maximum that the car or charger can deliver. Towards the end of charging the car requests a reduction in power, same as BMS system charging Lithium batteries.Yes it could be done
Tesla Rapids will only charge Teslas. Tesla Destination Chargers will charge other vehicles but only at 7kW.How? The charger communicates with the car in order to determine maximum power transfer and voltage. The feed is then adjusted to match the maximum that the car or charger can deliver. Towards the end of charging the car requests a reduction in power, same as BMS system charging Lithium batteries.
Once saw a VW e-golf plugged into a Tesla charger and after 10 minutes he'd received no power and had to move to the Ecotricity charger.
Yes, those that are on the machines in car parks and motorway services require an app or an RFID to start the process. The wall boxes generally don't but only ones with a 13amp socket or commando connector will potentially give 'free' electricity.I think you might need an account to use vehicle charge points, most I have seen appear to have some form of card readers attached to them.
Agree, but the charger still communicates with the vehicle to agree charging rate. A destination charger will charge at a higher rate if it's on a 3 phase supply and the car can take the charge rate.Tesla Destination Chargers will charge other vehicles
thanks for your answers, however i was asking if it could be done, not if anyone thinks it could be done or reasons why it might make other users unhappy.
When there were such things there was a mains supply to the lights. The phone mechanism didn't require power as such.? you have sussed it, me thinks phone boxes might be the answer ther'e already low voltage
youi dont need to do, but am interested to find out if it is possible to hook up to the electric car charging points to recharge batteries?
Has anyone ever done it, thought of it or carried out any research as to its possibility?
you need a 2.70k resistor on the cp pin to pe then put a 1.3k parallel on a switch to start charging,take your live from L1 for your 240v on board charger.i dont need to do, but am interested to find out if it is possible to hook up to the electric car charging points to recharge batteries?
Don't you think that motorhomes have enough bad press already MB.i dont need to do, but am interested to find out if it is possible to hook up to the electric car charging points to recharge batteries?
