Is it a Light or Maxi Chassis?
Kilsyth, Glasgow, UK
Since 2013
Can anyone tell me definitively is my 2020 Chausson 711 on a Fiat Ducato base a Light or Maxi chassis. It is not an Alko chassis but single leaf springs on the rear
Maxi is longer behind the sliding door and has side marker lights.
I’m pretty sure the maxi always has the twin rear leaf springs whilst the light is single spring, if so easy to see. I’m sure my maxi said so on the wing too
Maxi has the plastic trims around the wheel arches, such as the van above. Light chassis don’t have this trim.
Wheels will be 16inch with pcd of 5 x 130
Ours said Maxi on the back door
Thanks for all your suggestions.
Got the answer I believe - it is a Light Chassis! Based on wheel PCD at 118 mm and weights plate under the bonnet showing a D in the Version number.
