Internal lights not switching on or off
Angusweir
North Wales, UK
Hobby
About 6 years
Hi all,
Trying to get help on my hobby motorhome lighting issue....
The leisure battery was flat as we were coming away (must have left something on). It is now plugged in to why and things are working as they should, except the internal lights. Some are on, some are off, but the switch panel doesn't work at all.
It is a hobby siesta and has a light switch panel with an on/off button and also individual light switch buttons. None of these work.
At the master control unit I can disable all 12v systems and that works ok. But the light switch panel does nothing.
I took it off and there is no obvious issue.
I have tried long presses of switches, normal presses, double presses, disconnecting and reconnecting ehu.
No idea what to try next.
Any and all help appreciated.
Thanks, I'll give that a go. I tried turning all 12v systems off on controller, but a full disconnect is worth a try.
Thanks to Landy Andy, I disconnected the battery (well sort of, there is a key switch on the battery which I took out!) And when powered back up all is good. I can now enjoy the rest of my holiday😀
