Installing some shower drain plug holes
Roller5
Roller Team
newbie
I have a 2002 Roller Team Auto Roller 5....it has a bathroom with wc sink and separate shower.
The problem Im having is the 2 shower holes are on the side edge of the MH and water always flows the other way! And pools on the inside of tray no matter how much I try and level her!
I'm looking to fit 1 maybe 2 more shower tray holes. I can seen an extra indentation and was wondering how I go about fitting extra drainage?
I'm not familiar with your particular m/h but getting access to under the tray is likely to be problematic - impossible on mine without removing the whole tray, and that's serious work.
Surely you can 'level' the m/h so that it runs away through the existing drains?
Failing that you'll have to sponge it dry.
By removing the shower tray which probably involves removing the shower walls.
Not worth even considering in my opinion as it produces yet more potential leak areas.
Just use a rubber squeegee to push the last bit of water to the drain holes.
Hole saw cut would be no problem, but accessibility to the underside of shower tray to fix and route pipework could be.
Easiest way could be a small spirit level and over compensate your levelling.
Or as has already been said a good sponge ,good to sponge down cubicle with afterwards in any case (y)
Before you do anything, see if you have access to below the shower tray and look for any obstructions to an additional waste fitting and pipe work being fitted.
If it’s all clear you should be able to drill the tray, fit a waste fitting (inc trap) and run suitable pipe work to the other outlet and ‘T’ the pipe work into that.
The plug holes are so small the water still runs towards inside edge even after trying to over level. There does seem to be an exact circular indentation in opposite corner.
...here's some pics
