Illuminated bulbs on dashboard...
East Yorkshire
Elddis Autoquest 115
Few years
I have a number of warning lights that are showing but shouldn't be. I need to take the dashboard out and send it off for repair.
There are a few companies that can do the repair for around £150. Has anyone used one of these companies and can recommend them...
Also, are there any instructions that show how to take it as I need to remove it to post it...
Richard
Cartronix excellent service cant fault them
What age is your motorhome? Ours was replaced twice under warranty by Fiat.
Having said that believe Catronix solution may be the longer-term \ better solution!
Thanks. I’ll give cartronixs a call
Is it easy to remove it?
Was really easy to remove. Three Philips screws if I recall and simply unplug the connector.
But I'm sure Google will have a video as pappajohn has suggested.
whatever you do, don't turn the ignition key on with the binnacle removed. take key out before you start of course. sorry if this sounds condescending but I heard of at least one garage that did it. very expensive mistake
Edit see next post
