I Think Me Solar Power Is Bu**ered (1 Viewer)
Yorick
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
Just looking through this thread again? Would I be right in saying you have only one green light on your panel (indicating a low voltage on your battery) and yet your batteries are in fact full (12.7 V) ? If so, the problem is with your control panel, can you calibrate it ! (a fuse ????) (re-boot the whole system ?).
The panel has always been accurate. When it hits red, I know it's bad. If I turn the inverter on, the lights dim.
If I run the van for couple of hours, the split charge relay boosts it up to 3 or 4 bars
Will ask @Freespirit1 to pop round and have a nosey.
TheBig1
17,630
43,277
if you turn on the inverter and the lights dim, thats a bad battery
Feb 24, 2013
13,083
101,448
Bolsover, Derbyshire
Hymer S800
not long enough
how many lights were on the controller tonight when you checked the voltage at 12.6V it really should be saying fully charged, or as near as it can, as mentioned above (y)
Yorick
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
2 out of 4 lit :)
If I drive for a bit, it will show 3 or 4 lights
Feb 9, 2008
8,949
18,704
Corby, Northants
Coach Built
Is it possible, 1 out of 4 means 20% discharged 12.5V. 2 out of 4 means fully charged @ 12.7V 3 out of four receiving float charge 13.7 and 4 out of 4 receiving boost charge 14.4V
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
As Mr Big said, batteries. Your alternator can push a load more amps than the solar so if one or more of the batteries has a load of gunge inside partly shorting it out the alternator can drag it up to 4 blobs. Possibly.
Yorick
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
Sometimes after a drive, I've had it showing 4 bars. It lasts a lot longer from 4 bars than from 2 bars.
Yorick
Oct 1, 2013
7,512
19,937
Lanzarote
Nil by mouth
Lots
Aha, so mains 240v and the split charger relay will boost it to 4 bars, but solar only 2 ?
hilldweller
605
36,109
Macclesfield
Zilch Mk1
From Aug 2007
That's my guess.
You could try removing both leisure batteries and replace with a car battery and see if the solar gets a load of blobs with that. Easy with a pair of jumper leads.
