Not correct a van of that age will have the classic Hella projector lamps. You loosen 3 screws on the back and rotate the lamp a few degrees.Assuming they are not standard bulbs, if you remove rubber boot from rear of lamp there is a small lever to move. Its difficult to find first time and you may only get the tip of a finger on it, easier if you have a double jointed arm.
Try taking a few photos first as you will get camera/ phone in where your head cant fit, or mine!
This should help.thanks Lenny, had seen a utube clip showing the basic lamp with 3 screws , remove the fixed screw then loosen the 2 in slotted holes. rotate rear portion then refit fixed screw then retighten the screws in slotted holes. unfortunately the utube clip was a generic hella lamp. Will be visiting my mh next week and hopefully find a solution. not sure what happens on full beam.
