How to remove habitation door panel for access to lock?
Apr 18, 2020
56
40
Edinburgh
Autosleeper Stanton
30 years caravan, 3 years MH
How do you remove habitation door panel to obtain access to door lock on Mercedes Stanton?
It varies between vans, but generally remove the pull handle and the plastic panel is velcroed in place. A few have small self tapping screws around the edges
Most doors are made by Hartal
Suggest the OP submits a pic of the inner door panel. Most European vans opt for the Hartal door but since the Autosleeper is British they may use a different door manufacturer.
Many thanks guys and gals, now got the inner panel off but because the door is jammed locked can you unlock it manually ie without the central locking so that I can remove the panel completely and is there an exploded diagram of the hartal locking mechanism?
