How to keep mastic clean/white?
Probably been asked before, but how do you keep the mastic clean and white on your MH.
One other issue I have trying to clean the vans mastic on top/middle of the windscreen which is a hell of a job to get to.
colyboy
I cleaned mine with Autoglym polish. Did a decent, but not perfect job.
Keeping it clean? Another question.!
Try toothpaste on a soft brush worked amazingly well
Aa spray of the mould cleaner for use in bathrooms.... But keep it off the bodywork.
There is tubed gel type one that has built in brushes for attacking black mould in showers/bathrooms,
https://rover.ebay.com/rover/1/710-...0001&campid=5338547443&icep_item=392911792287
Again, not perfect, but good enough to take your eye of the offending area. I used the brush to apply it then set about it with a stiff toothbrush.
Might be available elsewhere cheaper.
Mike
i use astonish mould remover from bargain stores or b&m i have a 3 inch paintbrush wedged into a 3 foot piece of copper pipe and away i go easy to reach
A thousand witty replies suggested themselves when I read that !
