- Apr 20, 2022
- 93
- 54
- Adria Supersonic
Hi folks, I'm new to the forum, though have been a regular anonymous visiter.
Please can I ask for advice about the display on the solar meter (an EPever MT-1) on our 2015 Adria MH? The meter reports from the low cost EPever duo controller, which is fed by a 1040mm x 600mm panel, with the charge going into an LFD90 battery via an EBL 226.
On the solar tab of the MT-1, there is a figure for total Ah. Is this figure the total Amp hours the solar controller has sent to the EBL, or is it reporting the total amp hours the solar controller 'received' from the panel. The total figure seems very low to me ( < 4Ah / day) and the spot amps measure is rarely above 1.3 - though the meter says it has peaked at 6 (though never when I'm looking at it).
The MH is left on EHU most of the time, so I wondered if the MT-1 is just reporting a top-up value of Amps it's actually 'used', and it's so small because the battery is already full.
If it's not a top-up, then the output from this setup seems less than useless ( < 4 Ah / day) and I presume is broken in some way.
Any help interpreting the numbers would be good, as I couldn't tell form the manual what it meant.
