Geomore
Just back from our first ever MH stay, learned loads, but still loads to learn! Our fridge is a 2018 Thetford 3-way Automatic (one of the tall slim ones, I gather they are all pretty much the same functionally). Great bit of kit, but the manual doesn't quite meet my inquisitive standards.
- When it's on gas, if near to the vents, you can hear the gas burner. It sounds like a gas cooker sounds when it's windy - i.e. a very faint roar rather than pleasant hiss. Is this normal, or is it worth investigating?
- Apparently below 6 degrees (from memory) I should fit winter guards to the vents (which I will need to source). How critical is this? what will happen if I didn't - will the fridge just be rubbish at cooling or will the world catch fire? How about a cold night? I switched the fridge off overnight, as I considered it had a 5l water container in the bottom box so everything would stay cool.
- The fridge was initially set to Max (5/5). this seemed to correspond to "burn gas 24h/day". I set it to 3/5, and not much difference, then 1/5 and finally it stopped running all the time (note, this was after it was full of stuff and was already down to temperature). I guess this is ambient temperature dependent, maybe 1/5 is easily enough in this weather?
- Where do I buy things that actually fit in the tiny door shelves?! Should I somehow manage to buy enough food to fill the rest of the enormous space!
