How noisy is your water pump?
Kent, UK
Bessacarr E412
Ours sounds like a grumpy old tractor. (2013 Bessacarr, Truma). Only been woken up once (yesterday) by a similar noise from a neighbour. Is ours normal or do we need it seeing-to?
You could rubber mount the pump or it could be the pipework is knocking on furniture/walls etc as the pump pulses.
Easily sorted by securing the pipe to the floor.
4 PCS M3 Rubber Bobbin Mount Anti Vibration Mounts Shock Absorber Rubber Isolator Mounts Double Screw Studs https://amzn.eu/d/9WV8zQf
They all make some noise, depending on how and what it’s fixed to, how powerful it it and the pipes need to be clamped well or they vibrate
Mine has always been quiet noisy. I tried another the same but it was no different.
We call him grumpy, but we do (now and again) worry about waking the neighbours. Though we are away pretty sharp-ish next day 😆
According to its label mine's the original 1995 rubber feet mounted Shurflo in a dinette underseat locker and apart from a gentle whirring when it's in use it's as good as silent. Mind you, the 1995 internal furnishings and units are of pretty solid wood, unlike today's eggshell thin shiny plastic mouldings.
Do not mind it being noisy, at least I know when it is running, no taps left on, no leak. A couple of clicks every ten minutes or so indicates a leak or a failing pump NRV.
Good point!
I had to replace my leaking shurflo recently, testing before fixed in place it was noisy, screwed down too tight it was noisy, just screw down so the rubber washers absorb the vibration it purrs.
If the motorhome manufacturers adhered to the Pump manufacturers fitting instructions there would not be a problem. They incorrectly fit angle bends close to the pump, they mount them on thin panels which act like a drum and magnify the noise and they do not fit a length of flexible pipe to and from the pump.
Look at your pump manufacturers guidance on installation and follow that guidance, you will end up an acceptably quiet pump.
Geoff
Ours (2021 Burstner ) is pretty quiet. Have been known to leave it running (tap slightly open) and not notice. It is mounted inside the water tank - I guess that makes it quiter than external mounted pumps?
However, I was parked next to an older van (also Burstner) recently and I could hear when they had a shower and went to the toilet. It made a right racket!
Expansion/ accumulator tank after the pump can help.
Mines noisy too, changed until about 2 years ago but it still banging away. Been told that I have an air leak somewhere, have yet to find it, to be hones, I’m not too bothered.
The pump in our Hymer is a submersible one and it is very quiet. Much better than the Sureflow pump in our previous Adria. When one of us uses the toilet in the night the other is no longer woken up with the flush.
I fitted a Shurflo pump and a Fiamma damper using flexible pipe work, the pump sits on a thin plywood and foam base resulting in a very quiet pump. The original Whale submersible pump was a lot noisier.
Ours is noisy. It is quite powerful for a van (Shurflo 40psi), but also mounted on dampening material, on flexi connecters and boxed. Still noisy.
A couple of years ago I built a few vans for a friend. He had bought Fiamma 20psi pumps. When we tested the system in the first van, it was almost silent. We were both a bit bothered by this (pumps are usually a bit audible) so quickly ripped the covers off to see what was wrong. Nothing, it was just quiet. We put it down to luck, but after fitting out another 3 of his vans with the same pumps, they were all quiet.
So, I thought I'd try a Fiamma in our van. 20psi wouldn't cut it (instant hot water system) so I ordered the 30psi model. Noisier than the Shurflo. Sent it back.
In the Vario, I'm going to fit separate pumps on the hot and cold (hoping this solves an issue with instant hot water boilers). Very tempted to try the Fiamma's again, but this time 2x 20psi.
Our Sureflow pump is great! eh? what did you say? Oh!..... half past Three!:giggle:
We nickname ours Woody, as in woody woodpecker:giggle: Pressure is good, plus we don't have those silly taps with microswitches needed with submersibles so we are happy with "Woody" = pressurised systems less to go wrong, better shower pressure IMHO.
My advice would be check out your Sureflow pump installation & its mountings, if additional sound insulation is needed via rubber matt or similar, then check out what's available on Google, loads of double sided isolation double sided sticky base plate options available.
LES
Submersibles can be controlled by a pressure switch the same as diaphragm pumps.
Geoff
Geoff
I agree, and I have changed the microswitch system in our Hymer to run on a Whale pressure switch while still using the the Reich submersible pump.
Hymer here too with pump in tank hardly any noise.
Our Autotrail has a shureflo pump and its very noisy. Has been from the day we bought. Thought it was normal! Other half complains every time its used. Hadnt thought about refitting it on dampers. Thx for the advice.👍🏻
My one is noisy too
Do you leave your pump on all the time or only when you need water. ??
We leave our pump on all the time
