The instructions say 1 teaspoon per 4.5 or 5 litres, depending on whether you read the English or French instructions. . So, if my fresh water tank holds 120 litres I need to add approx 27 teaspoons of Puriclean? Not sure if I'm missing something.
Interesting. But I'm using the powder.I use a hypodermic syringe attached to a small length of silicon tube. The graduations on the syringe make it easy to draw up the correct volume from the bottle then insert the tube into the water filler to squirt the Puriclean in.
I came home yesterday, from 12 days away to find the heavily chlorinated tap water in my coffee machine had gone green. It’s not just the light, as the 5 litre containers I use for fresh drinking water every day get green or black in the shed over winter. Our tap water stinks of chlorine.Why bother very few others do - including me - ever.
Fresh water is dosed with chorine to keep that way.
But you don’t have to fill the freshwater tank. Half full will do the same job if you drive it around to get it sloshing about. Then put it through all taps. Then drive around again to slosh it around in the waste tank.The instructions say 1 teaspoon per 4.5 or 5 litres, depending on whether you read the English or French instructions. . So, if my fresh water tank holds 120 litres I need to add approx 27 teaspoons of Puriclean? Not sure if I'm missing something.
You're probably right, but we all have different situations to deal with. It's easier for me to fill the tank and leave overnight.But you don’t have to fill the freshwater tank. Half full will do the same job if you drive it around to get it sloshing about. Then put it through all taps. Then drive around again to slosh it around in the waste tank.
Could it be the water in your area?I came home yesterday, from 12 days away to find the heavily chlorinated tap water in my coffee machine had gone green. It’s not just the light, as the 5 litre containers I use for fresh drinking water every day get green or black in the shed over winter. Our tap water stinks of chlorine.
I often get black bits in the water out of the taps in the MH if not cleaned every year, black bits = bacteria in my book.
So I use puriclean at the start of every season.
Never had any problems like that. Chlorine does disperse after 4 or 5 days so always best to drain the tank after a trip, which I always do.I came home yesterday, from 12 days away to find the heavily chlorinated tap water in my coffee machine had gone green. It’s not just the light, as the 5 litre containers I use for fresh drinking water every day get green or black in the shed over winter. Our tap water stinks of chlorine.
sure some could be supplied if required., no sarcasm.
BrilliantDidn't know there was any choice when I bought it.
Grandchildren......in my van, I feel faint!!We use Citric Acid (food grade), dirt cheap on Amazon. Dose the fresh water, drive around a bit, drain out into waste tank, drive about a bit, drain, all done. If you want to save on diesel for the ‘drive around a bit’ just let the grandchildren play in the van for a couple of hours; similar effect !!
Brilliant for the boiler!!Never had any problems like that. Chlorine does disperse after 4 or 5 days so always best to drain the tank after a trip, which I always do.
The only thing our tank sees apart from water is a dose of white wine vinegar once a year when I'm descaling the boiler.
About 3 Lt and about 10 Lt of water in the fresh tank so I can fill the boiler and run it through the cold pipes as well.Brilliant for the boiler!!
How much white wine vinegar?
Really hard water down our way
