- Oct 10, 2014
- 312
- 294
- Hymer B680 Starline
- We are no longer Newbie's.
Fridge is an Electrolux RM6401L. Currently I have the fridge out on the floor of the van to check electrics after the gas was cutting out. I have access to the burner thermocouple and the thermocouple connection to the gas valve on the top and I want to check the function of the burner thermocouple before refitting the fridge. I have removed the 2 black wires from the white bit of the gas valve which go to the selector switch, and then measured resistance across the 2 exposed terminals on the valve which is about 0.4 ohms at ambient. Using a cooker hob ignition torch I heated up the thermocouple and watched the resistance increase to about 17 Ohms, then back to 0.4 Ohms when heat was removed. Whilst this shows the thermocouple is detecting heat I am confused as to how this works to cut off the gas when the flame goes out. I would have thought that it would have gone open circuit when heat was removed to shut the gas so can anyone with knowledge of this type of control say whether I am testing correctly and are the results what I should be seeing?
Thanks in anticipation
