- Jul 8, 2019
- 295
- 123
- Jap Import Nissan4x4
- Semi-newbie to motorhomes
I want to ideally fit 300 or even 400w of solar to my roof if possible. The criteria is that I want rigid panels, not flexible because they last longer, longer warranties and harder to break.
You see I have a ridge that varies in thickness running up the centre of my roof and its about the same width a many solar panels which means if i get the corner mounts that most of them seem to come with, it will be touch and go if the mounts will be on the ridge or not if i mount them width-way across the van ie left to right.
But if i mount them lengthways front to back then maybe the curve at the front will be an issue or the fact that at the side it tapers off a bit.
Is there much flexibility with the mounts so that if you dont have a totally flat roof such as mine you can still secure the panels effectively?
Any other tips for mounts, or which is best or anything like that is appreciated.
