Brianbtays
Got a new benimar mileo 282 and can't run hot water and heating at same time apparently there is a winter setting but I can't find it anywhere ...
The Combi 6 is 6kW on gas and 1.8kW max on electricity.The gas is 3kw but the leccy is only 1kw. Its correct that if you select boost the heating goes off. If you select 'mix' as the fuel it will use the gas until warm then drop back into leccy only.
That's my understanding anyway
