- Oct 5, 2012
- 4,283
- 9,569
- Carado T132
- 5 years, feel free to ask me about the Carado!!
I have one like this and it sounds like pain in the bum if you go cold weather camping. My experience is its got to get lower than 7 degrees for a pipe to freeze. Is your tank & pipework internal or external IE winterised ? Maybe just capping the end of the input pipe to the valve would do it, but if the system overpressures there would be a problem. If you can switch off the water pump seperately, how about leaving a tap open to guard against over pressure due to frost ?I was trying to drain it (now) in cas no need to take it apart and fiddle with stuff. Anyway update. I've kicked it hit it called it names and screamed while pressing stuff. Filling it up and the water is no longer draining out. Pump is off too. Thanks for all your help - I feel relived like you would not imagine! So - to stop this happening in Scotland- leave the water on and eat up into gas, or is there another ingenious solution I can fashion up?
