Zacshoomans
Hi all - this is our first trip away in coldish weather - and the boiler valve keeps emptying the tank - why will the safety valve be popping out when it’s only 8deg outside, and it’s nice and toasty inside?
The blue one dumps at 3° not 8°.Funny enough, I filled the van up today with fresh water and bled the whole system for the great escape tomorrow. Even though the vans tanks and pipes were empty over the last month whilst its been sat on drive, the Blue button had still popped out on the auto dump valve. Its very close to the manual one that had been left open between the double floor.
I remember it doing the same last winter, according to book it opens and dumps at temps below 8 degrees C
So I guess its doing its job.
LES
Hi TinaL,What van do you have?, as I cant find a manual on a "Not Yet" as listed on your Avatar
I have two dump valves for the boiler on ours, one is manual type the other is auto with a reset button, do you have similar?
LES
Yes....and I've spent a certain amount of time lying on the floor so that I could immediately reset it each time it popped, in the vain hope that it would remain set and not pop out again.You did remember to also press the blue button in when you reset the dump valve. If not, it will keep emptying.
Ours is the latter (i.e.: blue button which doesn't require 12V), although I think it is set to pop at about 8C - even though it is nearer 10C outside and somewhat warmer inside.There are two types the older one had a red button at the top and requires a 12v supply to keep it closed. Supposed to dump at 4-5°c but often dump at a bit higher temps. This type you can hold closed with a peg.
Also check it has a 12v supply.
The later type has a blue button at the bottom and blue knob on the top. These dump at 3°c. Not easy to hold in & new ones are over £100.
Could be worth taking the valve off and soaking in hot white wine vinegar as it could be not fully closing due to a calcium build up.
As I said in my eairler post they are set to 3°c and generally much more accurate than the older type.Ours is the latter (i.e.: blue button which doesn't require 12V), although I think it is set to pop at about 8C - even though it is nearer 10C outside and somewhat warmer inside.
Many thanks to everyone who has contributed...Hi all - this is our first trip away in coldish weather - and the boiler valve keeps emptying the tank - why will the safety valve be popping out when it’s only 8deg outside, and it’s nice and toasty inside?
If all else fails, RTFM, eh?...this morning I have found the truma manual...
Rookie error. But we have all done it and will do it again.Many thanks to everyone who has contributed...
...I can now confess that it is all down to user error...
...how long can we consider ourselves to be 'newbies', I wonder?...
...we can only see the blue pop-out button on the frost control valve...
...which was what kept popping out, only for me to push back in...
...it shows a picture of this valve and that it has a rotary switch on top...
...it is this rotary switch that I must have used a few weeks ago when emptying water from the home when it was parked-up, due to the cold weather...because it is the only way to manually force the button to pop-out...
...evidently I had forgotten about this and hadn't turned it back to operational...
...have now filled with water (again), water has remained in tanks AND we have hot water...
...yay...
Thank you to this lovely community for your prompt responses.
Merry Xmas one and all
Hello This is my first contribution to the site, so hope it works.Hi all - this is our first trip away in coldish weather - and the boiler valve keeps emptying the tank - why will the safety valve be popping out when it’s only 8deg outside, and it’s nice and toasty inside?
