- May 8, 2010
- 2,391
- 5,563
- A class
- Since 2010
I've read numerous posts on here about problems with springs in Hymer door locks.
Last year, we had a problem whereby we could not open the hab door from the outside. At that time the top latch on the door was not opening when we unlocked the van from the outside, but could be moved manually from the inside in order to open the door. That problem was resolved under warranty.
We're now out of warranty and a similar problem seems to have arisen with the lower door latch.
I've read posts which indicate that the springs in the locks are naff and often need to be replaced, and I'm guessing that this is probably the cause of our problem.
My big question is 'How the hell do you remove the latch?'
The above is the offending item.
In particular, I read a thread by Stewart J , in which he showed a picture of this latch having been removed.
A secondary, and related problem is that 'the bit that the latch locks into' (sorry don't know what it's called), on the upper fitting, is no longer fitted straight.
This has probably occurred as a result of trying to force the door to open/shut - so entirely our fault.
Again, we are at a loss as to see how to remove it in order to straighten it.
Can some kind and knowledgeable person please advise as to how we should proceed?
Many thanks.
Many thanks.
