Help! New bike and Fiamma rack (1 Viewer)
May 29, 2016
1,044
1,417
Hampshire
Carthago C-Line
Since 2016
Less than 6 weeks till our next trip and we decided to try the new bikes on the bike rack....they don't fit! :eek:
Hubby's bike is fine - if we put his on the outside rail we can use the existing bent arm block to attach it, but my step-through bike is more problematic. Without a crossbar obviously I need to either clamp to the seat tube or get a frame adapter to make a crossbar (I'd prefer using the seat tube). Seems there are load of different Fiamma arms/blocks - which one do I need? It'll be going on the inside rail (the one nearest the van).
Anyone have any experience of putting a step through bike on a Fiamma rack?
Popeye
Sep 5, 2011
7,926
86,461
edge of New Forest
Frankia Platin Plus
On and off since 1983
I have a clip on adjustable crossbar for my wife's step through.
I have this one.........
Strong, quick to clip on, attatch the 'Fiamma' arm straight to it.
Feb 9, 2008
4,094
5,915
SW Scotland
LP Coachbuilt
The Fiamma racks are very adjustable, we need a pic to help.
Howard H
4,832
4,795
West Lancashire
Benimar mileo 294
We had th same problem the company called Thule make an adjustable removable cross bar . You may find you have to turn the handle bars on the bike nearest to the van as well on my bike the handle bars where to close the rear of my motorhome for my liking .
Euphony
481
2,809
Perthshire
B Class
3 years of weekending with the odd month here and there.
Just back from a break with the bikes and my wife has a step-through,
Hers goes on first, the short arm lowers and the head rotates to lock on to the top diagonal step through bar. Mine goes outside with the long arm holding the crossbar. Our is a Fiamma too.
DangerMousy
May 29, 2016
1,044
1,417
Hampshire
Carthago C-Line
Since 2016
Usually quite simple?
Yeah that's what thought....until we tried it LOL
I thought about one of those, I'd prefer not to use one if we can get away with it though because due to the shape of the bike frame it'd have to attach to the seat post rather than the seat tube.
Yes we had that problem with the old bikes too. The inner rail on the bike rack is just a tad too close to the body.
That was kind of our plan....except I was aiming for the seat tube rather than the down tube (coz the downtube is very fat). But then we found the short arm won't rotate - didn't want to force it in case it wasn't meant to. Maybe its just stuck and we need to have another go at it.
Here's a pic:
Having spent a while looking through the Fiamma catalogue, I think the Bike Block Pro D1 might be what I need.
Trixie
Apr 25, 2014
636
2,422
Mine is also a step through but attaches by the bar at the bottom. It’s a fiamma bike rack.
Trixie
Apr 25, 2014
636
2,422
You could attach it with a ratchet strap or 2.
Oct 9, 2017
429
1,052
Wisbech
2007 Hymer B654
The head of the clamp should rotate. Squirt some silicone spray into it and then try it again. The head on the short clamp looks smaller than the one on the longer clamp, so I would look to put it onto the seat post/tube. You may find that you will need to slide the track (into which the wheels go) along to allow the bike to move over for the clamp to align with the seat tube. Slacken the two bolts on the track and move it to fit. Doesn’t matter if the tracks don’t all align together. I have moved mine so that I can fit two bikes without the handle bars clashing. I also re drilled the holes so that the bike nearest the back of a the van better fitted the short clamp, and this allows me to also put some pipe lagging onto the rack frame to put a strap around the bike also. Belt and braces.
DangerMousy
May 29, 2016
1,044
1,417
Hampshire
Carthago C-Line
Since 2016
The clamps are actually the same size - its just the perspective on the photo that makes them look different, though the downtube is definitely too big for the clamp anyway. Will have a go at the shorter clamp to see if we can get it loosened up.
We need to replace the rails anyway with the longer e-bike ones so its no problem to offset them if needed to line up the seat tube with the clamp (y)
Trixie
Apr 25, 2014
636
2,422
My fiamma clamps don’t rotate but I think the modern ones do
32,689
66,704
You could move the short arm to the side of the upper bar rather than having it on the top of it, it should then line up with the seat post.
DangerMousy
May 29, 2016
1,044
1,417
Hampshire
Carthago C-Line
Since 2016
Thanks for all the suggestions (y)
We've managed to get the smaller clamp to rotate - its still really stiff, but knowing that it should move means we're willing to force it.
Will see about exactly where to position the bike when the new rails arrive....if we can use the existing short clamp then great, but I've ordered one of the Pro D1 arms just in case (can always return it if not needed).
Ridgeway
3,670
6,203
Lausanne
NiBi Arto 85E
Even with the wheel straps and the clamps on I always add 2 ratchet straps, to be sure to be sure.
Sep 26, 2013
4,172
5,159
Market Rasen
Since 2003
The bike rack for a panel van is normally only held in position by the tension on the side fixings so being a belt and braces person I bolted mine on straight through the van door. In doing so I fixed in a cargo holder plate that I took out of the back of the van when I converted it. This means that I can put a ratchet strap through the top and bottom ones to make sure that the bikes don’t move. I suppose the door could fall off though.
