Help needed for 2008 Fiat ducato tribute camper van. (1 Viewer)
wrinklybottom
Mid-Somer-Norton
Michael Simmonds
I have a fiat ducato camper van. That will not start. Can anyone possibly diagnose the problem with symptoms that I mention.
Engine turns over... Plenty of fuel in the tank, But needle shows empty, with fuel light flashing. Central locking not working on key fob. Open and close buttons not working on dash. Hazard warning light button not working also. Even the indicator arm is not working on steering wheel.
Has anyone had the same problem. That can say what the problem is. And cause. And maybe cost of repair Cheers.
movan
21,492
120,753
Moving around
Burstner
since07
Is that what happens when your alternator has gone?
(I'm not very good so probably not.). :(
Oct 9, 2019
4,960
17,317
Todmorden
Van conversion
FUNSTER in a PVC
Sounds like fuse behind plastic cover right hand side of steering wheel dash
Derbyshire wanderer
1,297
2,396
Derbyshire
15 years
Sounds like the crash sensor has activated. Designed to stop fuel pump, unlock doors and activate hazard lights.
No idea where it would be fitted but always on the bulkhead and looks like a relay with a round rubber top that can be pressed in to reset
Aug 18, 2011
12,140
18,008
derbys
AUTOSLEEPER SYMBOL
Does the engine turn over or does nothing happen when you turn the key?? BUSBY.
17,635
43,369
immobiliser fault or more than one fault with the fuel pickup and other electrical bits. sounds suspiciously like a rodent chewed the wiring. it needs a proper looking at, not guesses on the internet
Jan 11, 2018
1,165
1,359
Malvern Link, Malvern, UK
Chausson Welcome 85
Since 2018
Could be the engine earth strap. This I understand can produce a range of symptoms.
To test for this get a jump lead and earth one end on the engine , the other to a body earth and try it.
Sep 1, 2018
1,986
6,652
Strathaven
Pilote G741
Since 2018
Initial thoughts would be key fob battery needs replacing and starter battery may be a bit weak from lack of use
First thing I would do , fob Battery flat so not switching the immobiliser offf
Jan 28, 2008
10,117
18,385
Dovercourt, Harwich, UK
Renalt burstner
7 years campers before that
i would start by putting a second battery on jump leads using the block as earth then see if it starts on easy start
17,635
43,369
but putting the key in the lock would trigger the immobiliser circuit. Multiple electrical faults could have a single point of earth at the ecu, but unlikely
