HELP Fridge Problem (1 Viewer)
Apr 29, 2014
462
253
Warwickshire, UK
Chieftain
Checking van over for 1st trip after being stood for 5 months everything normal until I plug electrics ready to put food in fridge keeps blowing leci in house so try on 12 volt still not working but working fine on gas van is on level so obviously electric short Is their anything I can check before I get a electrician thanks for any comments
Ivory55
6,017
14,534
North West Norfolk
Since Feb 2012
I am no mechanic or anything but recently we had trouble with our electric and it was the connection on the back of a socket in the under seat by passengers seat. This caused our electric to stop working, just a thought.
Abacist
3,750
10,790
Devon
N & B Arto 88F Tag
since 2013
I would check both ends of the hookup cable to see if the wires are still properly connected first.
Nonose
155
477
Gloucester.
Cl Riviera 121 (Vandora)
1previous van. Not had one for 3 years.
Hiya Sally. This may sound like a dumb suggestion but I was watching a fulltimer vlog recently and the guy in the vid had fridge problems too. He had a fix for it, he removed the fridge, took it outside and turned it upside down. He left it like that for 30 minutes or so then put the fridge back in position to stand (switched off,) for 24 hours. After that the fridge worked again.
Armytwowheels
6,475
14,881
Market Harborough
Carthago S Plus - Iveco
Since 2011
As above, possibly the hook up cable. Try boiling a kettle or running something off the 240v sockets in the van, this way you can either confirm or discount the fridge as the problem.
SandraL
1,373
985
Somerset
Hymer b694sl
Try things one at a time. Switch everything off in the van that is mains driven, if no switch then unplug. Turn the 240 breakers off in the van. Unplug the mains lead both ends.
Now plug the mains lead in at house end, has house "blown?"
If not pkug into van. Check house.
Continue by turning on 1 breaker in van, has house blown?
Hopefully you will find what is causing house issue.
Turn on one item at a time until you find the problem.
When you say house blown is this a fuse , perhaps a mcb or the house rcd?
Reactions: DBK
sally47
Apr 29, 2014
462
253
Warwickshire, UK
Chieftain
Thanks all for replies everything works fine on electric but as soon asi witch fridge on it all blows so definitely in fridge did wash the van few days ago wonder if water got in as got no vent covers is it possible to disconnect clean and reconnect wires from outside bottom vent?
bigtwin
5,241
9,945
Derby
Concorde
Yes, usually.
Make sure you disconnect the mains cable before prodding around in there though.
Ian
Abacist
3,750
10,790
Devon
N & B Arto 88F Tag
since 2013
If the fridge mains element has failed and is causing the mains to trip then just don't use the fridge on Mains electric. It should still work fine on gas when you are away and on 12 volts when you are driving along. We managed fine like that in our van until we could get an engineer to repair it.
Bart
3,188
1,398
Northern Ireland
Boxer L4H2 van build
Since 2016
Fridge on works on 12v when driving, I'd agree with others above that suggest blown electrical element in fridge, so just use it on Gas for this trip ( turn it of auto and select gas manually so it doesn't revert to electric automatically ) then replace the fridge element after your trip away.
Enjoy your trip
Jun 29, 2015
3,482
57,485
Southampton
caravan (for now)
on and off since 1984
Not the problem here it works on gas
Apr 27, 2016
6,873
7,995
Manchester
A class Hymer
Since the 80s
If the fridge won't work in any power mode, (mains, gas or 12V) then the problem is not the power but the refrigeration circuit. First make sure it's not just a levelling problem - the fridge must be within about 5 degrees of horizontal. If it's recently stopped working due to levelling problems then sometimes a bit of a shake-up by driving round a bit will get it going again. But if all else fails, taking it out and inverting it as described has been known to work.
But I'd say that's not the OP's problem
