Help!French campsite 5amp power supply,is this ehnough to power M/H fridge?+lights?
more than enough to power a fridge and a battery charger (as the lights will probably be 12v anyway).
That's why I said fridge and battery charger rather than what they were asking (fridge and lights)The 12V lamp power will come from the battery charger power but will only be a few Watts.
In theory 1st stage ECO Truma heating at 800W could also be used.
I saw a 1000W travel iron is Tescos the other day, with careful use 5A is doable as long as it survives the switch-on.
5 amps at 240v is 1200w..
Who does ironing in their MH?
You are very brave to say what a woman can and cannot do in the motorhome. HahaThe (now ex) missus insisted that we take a travel iron on holiday. It is still unused today and I suppose ought to be donated to a charity shop for another muggins to put in their luggage.
Who does ironing in their MH? I thought we all try to escape from that drudgery.
My thoughts exactly when I spotted it on the shelf
yes the 'rush' is significant. If people are pulling un reasonable power (un neighbourly) it will not leave much for you - a bit like site wifi where some may stream films and leaves an issue for others that want to use it for less hungry usage. I may have both of these points completely wrong if so I apologise!If your fridge switches off of 230v ( if it is an AES) it will probably be low voltage--- when everyone else is using max power available------ if his happens implug until the " rush" is over !!!!
But like everyone else said--- 5amp is enough for small draw stuff!! --- assuming you have about 220/230 v !!
AS once had a PVC with a fold-out ironing board. Not a huge success.
5 amp outlets are there for a reason, to charge batteries and power low wattage items only.
At the end of the day 5 amps is 5 amps, what you do with it is up to you.5 amp outlets are there for a reason, to charge batteries and power low wattage items only. They don’t want you using kettles, heating and other high power electrical items when you can use gas for all these.
So, why would you want to try and get away with using them?
I doubt that is the reason.Who says? Truma has had an ECO mode to make use of 5A EHU for ages!!
