Hella DRL Bulb Replacement
rikardo
Bath
Looking to Buy
Starting Out
Looking for suggestions to replace a broken Hella LEDay flex DRL bulb. Can only find suppliers to change the whole system out which is looking quite pricey. Hoping to just replace the defective bulb if possible.
Otherwise, if you can find the type of LED involved, you can get pretty much any type from Marlins. You will need to do some soldering, I suspect, but it's not too difficult, once you get a replacement LED.
Can you put up a picture of the label on that control box? That might give enough info to determine the type of LED. Also, examination of the wiring will show if they are wired in series or parallel.
Apologies it's taken a while to respond. Please see attached images showing control box and LED wiring.
