Heater/ cooling fan on fiat ducatto 2.3
Northumberland
Low Profile
The heating/ cooling fan only works on the high setting. Is there a separate fuse for the fan. The aircon only works on the low fan settings
You've probably burnt out the fan speed resistor or the connector. It's a common issue with the Ducato. I lost two in 4 years with my 2007.
The fan will continue to work on max because it bypasses the resistor. You can get to the resistor and connector from the passenger footwell.
EDIT: For me, it was actually the connector that burnt out the first time.
Passenger footwell:
This helped me when I replaced the resistor:
Thanks everyone for your help. I'm away in Wales at the moment but will definitely have a go at the weekend when I'm back home. It was showing 26° when I drove down to Wales yesterday so the air con was a big miss
