X250 ventilation fan faults/fixes
Discussion in 'Tech/Mech General' started by Techno, Jan 9, 2015.
  1. Techno
    Techno Funster Life Member
    Jul 28, 2010
    14,220
    15,203
    Leeds the one up North
    X250 4 speed ventilation fan faults and remedies.
    Various symptoms occur so lets look at these logically.
    The circuit fuse is no.8 40amp in the engine bay fuse/relay box.
    Between the fuse and the fan is a 30 amp relay in the same box.
    On from the relay is the fan speed selector switch, this switches a bank of resistors (resistor pack) that lives in the main airflow duct near the fan.
    The resister pack gets very hot in use which is why it is placed in the air stream to dissipate this heat.
    So if the fan stops working completely?
    Fuse gone?
    Relay failed?
    Resister pack thermal fuse open circuited?
    Fan motor failed?
    Speed selector switch?
    First check the fuse with a meter.
    Check the relay by borrowing one of the others in the relay box.
    If the fuse was OK and the relay is OK then try a new resister pack.
    If the fan suddenly only works on full speed?
    Replace the resister pack or try closing up the female spades on the electrical connector first, there are 4 connections.
    I've not experienced fan motor failure nor speed selector switch failures myself.
    **Pictures of left hand drive model. (transpose for UK)**
    Fuse box is the same for both
    [​IMG]
    Relay pack low level behind passenger glove box aside of fan motor.
    remove 5.5mm head screw
    [​IMG]
    [​IMG]
    squeeze the tabs on opposite corners and slide the pack in the opposite direction to the screw. It will then drop downwards.
    [​IMG]
    [​IMG]
    Fuse and relay may be different on 2011 onwards models but the principle is the same.
    EDIT in fact this will be pretty much the same on very many vehicles.
    This is deliberately kept very basic.
    • Like it Like it x 7
  2. Jaws
    Jaws Funster Life Member
    Sep 26, 2008
    18,874
    23,573
    Narrfoook
    Cor !
    I aint seen a wire wound like that green one since the days of valve based tele's !
    OK, they were usually cylindrical rather than flat but same principle
    Great write up again Andy (y)
    • Thanks Thanks x 1
  3. Techno
    Jul 28, 2010
    14,220
    15,203
    One FUN member has just self repaired their fan as per this article (stopped working completely) and in their case it was the relay.
    I have sourced a genuine new one £2.75 + 90p p&p (y)
  4. gailsunnymeed
    gailsunnymeed Funster
    Sep 29, 2012
    76
    455
    Wakefield
    Yes with your direction and instruction you have a saved us many pounds you are a hero to us x
    Gail and Karen
    • Like it Like it x 1
  5. Techno
    Jul 28, 2010
    14,220
    15,203
    Saved your Fun membership fee for sure (y)
  6. Drexxer
    Drexxer Funster
    Oct 26, 2014
    279
    303
    Lincolnshire
    VW Transporters, suffer from that problem, ok on full speed but bugger all else
    Great fix(y)
    Andy
  7. Techno
    Jul 28, 2010
    14,220
    15,203
    Resister packs very cheap on ebay, I paid £13.55
  8. ebo
    ebo Read Only Funster
    Nov 9, 2009
    65
    56
    Essex
    Great article thanks
  9. Dobbo
    Dobbo Read Only Funster
    Dec 17, 2016
    3
    Woking
    Hi, I was just able to leave for our summer break in Europe and started the van and noticed fan had stopped working. Just looked into the issue the first thing I changed was the air flow regulator which didn't fix the problem.Fuse also ok so looked at help on the internet and came across your post. Your help has been invaluable as I have been to the dealer and they could not identify where the problem lay. With your help with the relay fuse box image I ordered one on line and changed it. Fixed the fan now all fine so may thanks to you. I can't thank you enough, main dealer prices are mad and this part cost me £2 on eBay !
    Brilliant post. Thanks again
    Paul .
    • Like it Like it x 3
  10. Techno
    Jul 28, 2010
    14,220
    15,203
    Thank you that warms my cockles :xgrin:
    Leaves you enough change to subscribe to FUN :xThumb:
  11. Techno
    Jul 28, 2010
    14,220
    15,203
  12. ultima
    ultima Funster
    Mar 24, 2010
    203
    81
    stoke on trent
    My fan stopped working a few months ago-tried fuses and everything else.Was talking to an old mechanic friend week after "just give it a thump underneath -sometimes works " he said .Did so and it kicked in and has been OK since !!
  13. Techno
    Jul 28, 2010
    14,220
    15,203
    That would indicate poor electrical contacts. Better to fix it than thump it or it will just reoccur.
    Old mechanics are dodgy on electrics :xlaugh:
  14. ultima
    ultima Funster
    Mar 24, 2010
    203
    81
    stoke on trent
    Think it was just the brushes sticking if it persists again will fix it.
