Does anyone have any tips for a wall-mounted heated towel rail for the bathroom?
My first thoughts were a conventional chrome water-filled towel rail (the sort you'd connect to your heating or hot water loop in the house) with the pipes sealed off, filled with water through the bleed hole at the top and a summer element 150W (0.6A) fitted. Run it off the inverter, the element has a thermostat so you just keep it ticking over
Or would you plumb it in to the central heating (diesel-powered in our case) and keep the summer element for when the c/h not in use?
