Halogen bulbs
Alexandra
C class
Halogen bulbs can I replace with LED’s the bulb has the following On:- Ring auto 12v 10w 30 I have looked in amazon but wasn’t if they were correct. Alex
Depends if your headlights are can-bus controlled.
If they are you need special error free LEDs.
Also, I'm not sure but they could also be an MOT fail point as they weren't fitted as standard equipment.
Hi sorry they are the internal spot lights. I should of said. A
Sorry, no idea where I got the idea you were referring to headlights.
Must be tired or something.
Yes, just find the equivalent type LED.
Same pin/base type and a size which will fit.
A 10w halogen will be around 1 to 2watt LED.
If they are this type (12v 10w 30 says they are) you may find a suitable LED is a flat disc with two pins on the back.
This is known as a G11
